blushbaby »
https://forums.nicoclub.com/blushbaby-u60788.html
Mon Feb 18, 2008 7:02 pm
2) it's possible, how many miles are on your car? when was the last time you has it changed? it just might be time to have it replaced...It has like 83k miles on it. Had the catalytic thingy changed? ive never changed it. Ive only had the car for 9 months
3) check your hoses, make sure they are sitting flush on both ends of the connections, and make sure your clamps are still good/tight....Someone showed me a part where it might be the hose. ill check it again
4) not sure what you mean by shaking, starts, and stops, and starts again... again I ask how many miles are on your car? when was your last tune up? when did you last have your FI's cleaned? when at idle, does the needle jump at the same time you get this errattic shaking??? - it's possible there's a valve leak...What is a tune up? Is that like an oil change? I get the oil changed regularly. And what is a FI?!! No, the needle doesnt jump
Thanks a lot for your reply [/QUOTE]
