jrb92se »
https://forums.nicoclub.com/jrb92se-u35859.html
Thu Nov 23, 2006 4:44 pm
ive got the power fc i had it tuned at xat since then when i drop a gear or accel hard i get crazy knock readings of up to 90, before they tuned i, it was fine. while i was there i got an eletronic boost controller, first time i got the high knock reading was the first time i used the high setting (11.5 psi) i called them , and martin says its the timing and that i need to bump that thing on the front of the camcover one degree to the right but i dont want to **** with it..... then today it started doing something else so its starting to worry me, when i leave it in gear and let off the gas to decelerate instead of going to 0% inj. duty cyc it stays at like 1.5-2 % and sputters and sort backfires, if i tap the gas it will stop and go to 0 inj duty. has anyone else had this problem? can some one help me out i dont want to f*** my car up>>>>>sorry for the long post<<<<<<<<thanks for any help, edit: im running regapped plugs at .7mm could that be part of the problem?
