that was actually the first thing i had checked and the fuse is fine. thanks anyway...the links were helpful but im going to be able to replace them with LEDs..ill prolly just mess something upmaxhopper97 wrote:First, check your fuses to make sure one hasn't blown. As for bulb size, you got me...maybe Audtatious can help out on that.
As for how to replace them, here are a couple of links describing how to convert the existing bulbs to LED's. This will at least give you an idea on how to dissasemble the components.Climate ControlHazard/Defroster
i would have done that, but im not sure i can take the dash apart without messing something up.maxhopper97 wrote:The links were merely to give you an example of how to break the components down. There are factory bulb replacements available, I just don't know the bulb #'s off hand. If you take a factory bulb in to an auto parts store, I'm sure they could match it up for you.
