norcals14 »
https://forums.nicoclub.com/norcals14-u42070.html
Mon Apr 09, 2007 9:14 am
thanks for the quick reply! and ya there is a proper flange for it... I cleaned it when I had it off... do they go bad often when taken apart? I had to extend some lines could that be the problem? could it also be a short in the wires or something? and should it stop doing that when the car is warm even on start up, or is that an ecu thing every time you start your car?
