Your air regulator valve is no good.bias wrote:Well everything is going well with the CA:) Everything except the idle at start up. When I crank it up on cold or hot days it want's to drop to 500rpm. I have to rev it a little and then it's Ok? I checked for boost leaks and everything is good. I did some searching and it could be the IACV. Has anyone had this prob? It just started doing it. I been driviong the car for almost 6 months.
