Problems with HID's
MEAN1NGoFLIFE
Car: 1993 Nissan 240SX SE
my buddy was installing an hid kit on my car and everything works fine but when the light switch is off the hids are still on . a while ago i did the sleepy eye mod by cutting the brown wire, so im wondering if this is sending a signal to the hid relay . for example if its bypassing the lighting system or anything. anyone have any ideas on what could be the problem?
Modified by MEAN1NGoFLIFE at 6:07 PM 7/15/2009
maximaRIP
Car: maximaRIP 240sx 1976 chevy van
was this a plug and play kit?
MEAN1NGoFLIFE
yea pretty much . wired up to the battery and everything . the lights work fine but they just dont turn off when their supposed to, they stay on
Modified by MEAN1NGoFLIFE at 7:27 PM 7/15/2009
maximaRIP
it should try taking out the relay to the headlight well on, one at a time to see they shut off then mark that and swap with ones of the working ones and see if that solve the issue
and more things i do this to all my hid install ,install relays so the light take the feed from the battery versus the factory harness the wires are thin and old
MEAN1NGoFLIFE
yea well try that and see . but do you think cutting the brown wirie in the high beam button for the sleepy eye mod is causing this ?
maximaRIP
no the brown is only use to pass current to the motor when closing(there go sleep eyes)or the contact point on the steering switch are weak or dirty and are making still contact
r3v_v3ng3
Car: 91 fastback ka-t
MEAN1NGoFLIFE wrote:yea pretty much . wired up to the battery and everything . the lights work fine but they just dont turn off when their supposed to, they stay on
thought its plug and play, howcome you wired it up to the battery?
maximaRIP
yeah ur right i didnt see that ,i know my are too plug and play ,but i put relay on my cause the factory harness suck,to thin and not enough output to make them run full power
r3v_v3ng3
thats probably why its on all the time cause he has it hard wire to the battery
