matrix_canya »
https://forums.nicoclub.com/matrix-canya-u241492.html
Thu Aug 11, 2016 8:06 pm
This has been happening for the last two weeks and I am fearful that if the problem remains uncheck I will damage the car beyond repair. My car is a 2006 M35. So while driving fast (avg 50 - 60 MPH. revs about 3500 to 4500rpm) going up an incline to my home everything seams normal. However once I am close to the top of the hill the car always sound like it racing and then suddenly jerks forward once then slow to a hault. The moment the car jerks the display for gear selection on the dash board goes blank and I am unable to select any gears whatsoever. In order to regain control of the vehicle I have to pull the handbrake, switch off the car, push the gear shifter in park and wait for a minute or two or five before restarting the car. On starting everything (even the gears) functions as normal. This happens when I am using either automatic or the manual side of the transmission (it doesn't matter).
About a month ago, I had replace the front and back crankshaft seal because of an minor oil leak. I have alway been uptodate with maintenance
The car is not under warranty. I was told by a mechanic that it was the control valve body which I have since replace but to no avail. I also replace the knock sensor located on the transmission as well
Selling the car now is not an option because of the monies a recently invested in it (trying to fix the bastard) and car has always been faithful to me.
Does anybody out there know what the problem is????? Someone help me please!!!!!
