Problems with fuel...
SrSLeePeR
Well..Some of you might have read my old posts saying that my car was bogging, lagging, ish like that. Well, I swapped the fuel pump from a 300z BACK to my 240 pump. Worked well, but still bogged. 2 days later, the car doesn't even want to start anymore. Checked all the plugs, and they're firing. Fuel pump is working, Igniter chip is fine. All coils are fine....After 2 days of messing around with everything I can think of, turns out the injectors aren't spraying. Not even a single one. So, what can be wrong? All my problems led to this and now I know what the problem is. But now, I have to try to solve it. Anyone have any clue what might be wrong? Wiring? If so, how can I check? I don't think they're clogged because non of them spray at all, so I'm here still confused. Any help is greatly appreciated.
-Albert.
SrSLeePeR
anyone?
S13240
Try replacing your old fuel filter with a new one? Tried installing someone else's fuel injectors to see if that solves the problem? Try swapping parts from a friend's SR if possible, it can help you a great deal and save lots of time.
