Problems with factory stereo reinstall 1993 G20
Post all your Nissan electronics, car audio and stereo questions here!
jcmurp
Car: 1993 infiniti G20
Posted in wrong forum before soHiJust purchased this car at a really good price.They had removed the original factory and replaced it at some point.Before I got the car they had removed there amp and head unit.I was reinstalling the factory stereo purchased from a shop for a 1/93 and newer model(mine is 11/93 model) it has the amps in the trunk on the deck.They had left all factory wiring untouched soooo just plug the factory head back and go I thought.That did not work.This stereo has a pigtail hanging off (a round plug with like 6 holes in it) I can not find anything yet that it plugs into does anyone know? Is it for the amp? anyway I plug it in and try it with the unit out(not mounted) just plugged in and the antenna goes up,lights on and no sound.Anyone help with this? I would greatly appreciate it.I checked the fuses for the amp and they are fine. and how would I check the amps
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Try screwing it down and see if anything changes. Nissan doesn't put ground wires in the harness.
jcmurp
Well I did screw the radio in the hole and no change.Let me know of anything else you can think ofThanks
jcmurp
Fixed it,The aftermarket they had put in blew both amps.Replaced and now all is well(until I upgrade it)
