Thanks, Where's it located?chaosli wrote:might be your motor linkage i have the same problem i got to fix it tho
Thanks, I´ll check it, if the motor was bad, will a motor from a usdm 240sx fit? Thankschaosli wrote:you could take you dash out for easy acesses
or
you could take the floor vent on the passenger side and the radio out. it should be all the way in the back. change you temp and see if it moves if not you need a motor if it dose you need to to make something like a coat hanger linkage and a bolt so the little plastic clip wont strip again.
i think mine stripped need to check ive been lazy
Do you know of any page that sells conversions? Thanks...chaosli wrote:usdm dont have that motor, usdm use a cable from the hvac to the door flap. you need to buy motor from someone that sells the conversions they usally go for 60buck
checked it today, and the motor is'nt working... Thanks for your help94_240sx wrote:
This guy used to have a lot, but last time I checked, he's out of them.
http://www.ecrater.com/product.php?pid=640748
