dysfunktion »
https://forums.nicoclub.com/dysfunktion-u145100.html
Thu Nov 18, 2010 2:25 pm
Hello, thanks for taking a look.
So I'm having some trouble with my 89 niss 240, some basic details that might be relevant to know listed below:
stock ka24e
j30 diff
hks coilovers
lowering springs
my suspension is very stiff, so my car will bounce on the smallest crack
The problem I'm having is using this car as a dd as well as drift car. It seems like it slides too well, everytime I take a trip over like 2hrs, or about 120mi, i get out and see that my rear tires are completely f'd up. They are down to metal within a weeks of buying NEW tires, and these are my dd tires, not drifting tires. This is what I know, I originally had a welded diff that I swapped for a j30 because the weld was about to break and it was no good as a dd, When i drive in the rain, just the smallest bit of extra power will send my car into a drift, which is fun...but impossible to drive in the rain. When i try to drive straight on a wet road, i can feel my car sliding back and forth. At first i thought it was just the tires, but when i replaced them with brand new tires, the same thing would always happen. As nice as it is to have an easy to drift car, it has become very expensive and time consuming. I'm looking for any ideas on what might be causing this? My best bet is the j30 diff, i think it is transferring power back and forth too much and that is what causing my car to slide back in forth in the rain. I also noticed that when my tires are startin to go bald, somethin as simple as driving over the painted lines on the road or any slick surface will cause a tire to slip.
Any help or ideas would be greatly appreciated.
Thanks
