hamsterball »
https://forums.nicoclub.com/hamsterball-u17566.html
Fri Sep 24, 2004 12:23 am
it's not necesarily a fuel pump problem guys..
if it dies when getting out of gear and dropping it in neutral.. then it doesn't have to do with fuel delivery.
it looks like it's stalling when decelerating and dropping to neutral.
i bet your idle drops from 3,000RPM to 500RPM really really fast right? it's supposed to drop straight to idle and hold still without going under idle normally.
if he was staying in 5th gear and pushing gas, with the car hesitating to accelerate or losing speed with foot on gas, then it would make sense for it to be a possible fuel delivery (fuel pump or something else) problem
but it looks like he's having his idle dip and fluctuate. same problem i have (except everybody's idle dips and fluctuates differently )
there's actually another thread on this on this same Technical board just a few posts down.
Anyways, I'll get straight to the point.. check your IACV.how?- If you can start the car with the gas pedal HELD DOWN ALL THE WAY, then something's wrong with your IACV (Auxiliary Air Control part)
- While car is idling, check if the engine speed drops when squeezing/pinching the hose that goes to the IACV. If it does not drop, then something's wrong with it (specifically the Air Regulator Valve part of the IACV).
You should take that part out and clean it thoroughly. (clean the intake manifold/throttle body/throttle plate while they're out too. you have to remove the intake manifold to access the IACV on SOHC KA's.)
look up on how to remove the intake manifold and make sure you get a new intake manifold gasket when putting it back on after getting everything cleaned/replaced (hopefully you won't have to replace your IACV).
Good luck.
