Problems with brakes!
chineybutu
Car: 93 240 sx
Hello, I'm a newbie!! just inherited a 93 240 sx
Well here it is, i was bleeding my brakes, but was unable to bleed the left rear, the nipple seemed to be stuck, and i did not want to force it, just in case i broke it. Any suggestions on how to crack it? I used WD 40, but it still didn't crack
thanks
Ligouri Rd
Car: '96 Nissan 240SX
Pb Blaster
chineybutu
Car: 93 240 sx
Pb Blaster?
boznuttz
Car: MS13
...Or WD 40. Also try some Liquid Wrench. You need to spray the entire area periodically, then just give it tiem before you can break it free. I also think that the 10 mm nipples can be easily stripped since the metal is a softer grade( I have only heard), so be careful!
Zion8561
Car: 92 Nissan S13 Fastback
If it strips, just use vise grips and get a speed bleeder to put in there.
chineybutu
Car: 93 240 sx
thanks, will try, if not i am just going to get my calipers rebuilt!
