hamsterball »
https://forums.nicoclub.com/hamsterball-u17566.html
Thu Nov 03, 2005 12:47 pm
Hello,
This is on a KA24E, Nissan 240SX 1990. I am using the bleeder screw hole that is on the intake manifold in front of the connection of the upper radiator hose of course.
My bleed procedure:- Car is completely cold
- Take radiator cap off and unscrew bleeder screw.
- Turn car on.
- Car heater is on hot all the way.
And when I used to bleed it before I installed a new thermostat, it used to go like this:
First the radiator cap hole overflows, so I put the radiator cap back on.
Then after a couple minutes, I see coolant spit out of the bleeder hole, and then I put the screw back on.And it wouldn't overheat.
At the current moment that is not happening.
As soon as the car starts (this is on level ground btw, I tried doing it on my slanted driveway, but the same thing happens)..
The radiator fluid doesn't start overflowing.
The bleeder screw starts overflowing and you can see bubbles in the fluid.And coolant just keeps spitting and flying and flowing out of the hole until there isn't enough fluid to flow out of it.
Then I plug the bleeder valve when I see that, and top off the radiator.Then the radiator starst overflowing so I cap the radiator.
And then you think you're all done, but it still overheats after driving.
Every single time I do it, it's the same scenario..
Notes on car:- Fan clutch is fine, but doesn't have too much resistance.
- New radiator, new thermostat, new upper and lower hoses (upper hose a few montsh ago, lower hose a year ago)
- No leaking. Shroud is cracked but on securely
Why is the air not bleeding? Why does the coolant start overflowing out of the bleeder hole before the radiator cap hole?
Please help me out. Thanks
