I have never disconnected my battery. Usually it happens when I am using them. I will be rolling the window up, and then halfway it goes back down. Then I try to put it up and I have to manually do it.AlexM. wrote:Do you disconnect your battery a lot? I think it resets after every time you disconnect
A_Hole wrote:you have to reset it. It's in the manual. I think you have to roll the problematic window down, then roll it up all the way and keep holding the button up for like 5 seconds. That should do the trick.
Thanks! The window is now fixed!mattyfo0z wrote:I'm pretty sure I read it on here actually, there's a simple little trick that you gotta do to re-enable the automatic rolling up. I wanna say it's that you just push down the button all the way and hold it until the window's down, then for like 5 seconds more, then let go and it should roll up automatically again?
Let me search for a bit and see if I find it.
EDIT: I had it backwardshere's the correct way:
OK. I will have the dealership check it out. I have 40k on it now and I have until 60k before it goes out of warranty.DJBeasy wrote:What Im saying is that this shouldnt be happening for no reason. If it continually happens, there is an underlying probrlem that should be looked at. If you are still under warranty I would make an appointment to have it thoroughly inspected before you are out of warranty and SOL.
Well I want to say the bumper to bumper warranty is only 36k miles or 3 years.... that's what I got with my '06 Sentra, and '09 Altima Coupe.. just over a month ago I was around 59-60k miles and they charged me $300+ to replace a leaky shock..... in fact well before I reached 60k miles they quoted $300 to fix it, which is what kind of pissed me off because the warranty had ended last year @ 36k miles..elderboy02 wrote:OK. I will have the dealership check it out. I have 40k on it now and I have until 60k before it goes out of warranty.DJBeasy wrote:What Im saying is that this shouldnt be happening for no reason. If it continually happens, there is an underlying probrlem that should be looked at. If you are still under warranty I would make an appointment to have it thoroughly inspected before you are out of warranty and SOL.
I bought the extended warranty.CoupeVQ35CVT wrote:...
Or maybe Nissan stopped cheaping out or knows they better warranty their cars for a bit more if they don't want to piss off customers? haha...
But yah the auto-up feature on my coupe also seems to stop working now and then, not often but just now and then. I must be doing something and not realizing it like holding the button up after the window's reached the top, causing it to reset into the other manual up mode? Hmmm..
