Problems with 1993 j30 Battery/starting
xtacx
Car: 1993 j30 Infiniti
Hello Forum,
My battery keeps dying, and I keep needing a jump. I baught a new battery and it wouldnt start, I than proceeded to jump the new one with the old one, and it turned on. Now I would assume it's 100% the alternator, but sometimes when I do jump the old battery I could leave the car off for 6-8 hrs, and come back and the car would run, what else could be the problem?
Thanks in advance
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Im thinking the alternator as well... Sometimes if you leave the car sit for a while, it will sort of charge up enough just to turn the car over barely..
Keep that new battery, and use it when you have that alternator replaced.....
driverdriver
Car: NICO's longtime resident Canuck!!!
Your alternator is in the "on" position. It happened to my J. You need a new alternator. Make sure you get the Nissan one. All aftermarket alternators have a horribly short life (this board has many examples).
vicQ45
Car: 1979 Cadillac Eldog, 1987 Wagovan, 1968 Firebird 400
same thing happened to my maxima. replaced it about a month before i was rear-ended on the highway and totalled it . like everyone says, make sure its an OEM alt.
