well after i installed the LED lights on my doors i found out that the lights stay very dimly on when the doors are closed/armed but not when the car is on start. I used two LED on each side each LED is 3.6v and attached 330Ohm resistor to the + side, the led's are hooked up in a series circuit
***THE RESISTOR IS 330Ohm NOT 220Ohm I tried with 220Ohm ans was the same ***
am i doing something wrong here or is this normal for the LED's the bulbs are not cheap ones bought them from radioshack $5 a piece thanksD
