ummm wtf are you talking about????? if he says there is something wrong wih my vacume since mine is at 10in hg, then I say " i think i found out where my vacume leak is coming from, the stock sr bov that is not recirculated" dont you think that is paying attention to structures240sx's post?? I think so man the stock sr bypass valve leaks at idle which is giving me a vacume leak believe me ive paid attention to everyones post, and yours was usless im going to rec the bypass valve tomorrow then hopefully everything worksNateDogg wrote:You should re-read Structure240sx's post. He gave yousome valuable info but you never paid attention. If you ask for help and don't listen then that's just the most annoying thing.
You vacuum should be around 20-25in Hg at idle.
i noticed when i start to accelerate my vacume will drop from 10hg to around 18-20 so my guess is as i acclerate the bypass valve starts to close, makng my vacume to how it should be. My car idles really good/ smooth, and cruses nice and smooth, besides the air fuel ratio's switching from 14's to 16's some times 17's (while on 460 injectors, crusing, and at like a +16 on the safc which is weird. Im also thinking since my car is trying to stall out that is what may be giving me these weird rich / lean air fuel ratios. it will run very ritch then will run lean possibly the non rec bypass valves fault. and i do not have deceleration corrections. oo yah i also have a boost leakCraving4Boost wrote:idles are always weird...if you know everything if fine and you still idle around 16afr..thats ok you lose some normal behaivor using a piggyback...but if you still have 10inhg vacuum then you still have a leak
how does it feel cruising? smooth?
shouldnt your be set at 20 degrees BTDC?AN89HATCH wrote:i dont know if the injectors are clean but i can gett hec ar to idle at at 14.5 air fuel. and rite now i have my timing at 11 degrees
you have the exact issue as me...as i currently still have the problem. i have 12inhg vacuum and when i give it partial throttle it would go down to 25 at most. it is a vacuum leak and once you find it and fix it, it will be good. do the DYI boost leak test and see where it is. im sure if you pinch your wastegate vacuum or bov or any of them...some of them may make your boost gauge go down to the actual vacuum your car should have. however you cant just keep pinching everything so just do the test. im trying to borrow an air compressor from a friend so i can do this test...whoever said you can use a bike pump is WRONGAN89HATCH wrote:
ah, I'm SOHC too and running at 20 BTDC. I guess I should do some adjusting tonight but I havent had any issues in the past 3 weeks... Im running .5 bar (7.35psig) as well...AN89HATCH wrote:"shouldnt your be set at 20 degrees BTDC?"
my motor is a sohc so stock base timing is 15 degrees, and im runing 7lbs of boost so 11 should be pretty safe ( its been working so far lol)
im on the stock sr bypass valve lol, so thats why i was having all those problems. I think the only real way i can run my rec hose with out a kinck is to get a bov i can mount on my hot pipe. the sr bypass valve is on the smic and my rec bung is on top of my intake so it sorta has to make a up side down J with out a kinkCraving4Boost wrote:i'm sorry if you've said it before...but what BOV are you using?
thats also what i was thinking, i think it is a little to high lol what turbo are you running and what is your hi throttle point? I want to lower it I wonder if i should go to something like 20 lo 40 hi my turbo is a 50 trim t3/t4 and i dont start boosting untill 3400-3700 rpmCraving4Boost wrote:60 for hi throttle point is sort of high dont you think? but why tamper with a perfectly good working car...im glad its all working out good...as i yet to still overcome mines lol....sigh..stupid crave 4 boost..why does such a thing exist...
using the z32 hose may actually work, ill get some pics up soonBillKlineVT wrote:I run 20 LO and 50 HI... I decided on that while datalogging my AFRs because I noticed I got into boost around 20% throttle and it interpolates the a/f trim % when youre between 20 and 50, so its a good mix for partial boost. Not sure how your recirc hose is now, but I ended up using a recirc hose from a z32, just trimmed it so it was a short 90 degree bend. It's like a radiator hose and really stiff, really hard to kink. Post a pic maybe someone will have an idea of a better solution for recirculation routing.
