Problems up in till now.
CodeRed
Car: 2008 Nissan Versa S MT
This is a log showing the problems ive had with my Versa up in till now. Now this is not showing how 'bad' the Versa is, it is simply a log of the problems I have had with MY Versa. Hope your Versa isn't plagued with these problems. These are direct quotes out of the receipts they gave me. No, they can't spell.
Bought car on 11/11/06
3/21/07Mileage: 2,700"Customer state driver window does up slowly and when it hits the top it sounds like it hits hard.Found window hitting top hard when closedAlso found moving faster then other windowOrdered LF window regulator to correct."Price: $0.00
4/2/07Mileage: 3,111"Customer states LF window bangs hard when going up.Found LF window glass run rubber deformed.Replaced LF window glass run."
"Customer states brake peddel squeekingFound brake pedal switch bindingReplaced switch"Price: $0.00
4/11/07Mileage: 3,497Oil change.Price: $0.00
5/4/07Mileage: 4,403"Customer states RF door sticks when. VerifedFound RF door handle assembly bindingOrdered part"Price: $0.00
6/1/07Mileage: 5,353"Customer states RF door handle INOP . SOP here . See KalStock unit for rest of partsFound handle locking lever has no tension cableReplaced handle assy"
"Customer states LF window goes up slowly and clunks near topFound motor fast travel and regulator making noiseMotor failed internallyReplaced regulator and motor assy"Price: $0.00
6/19/07Mileage: 5,892"Customer states LR park light outFound bulb burnt outReplaced LR bulb"Price: $0.00
7/5/07Mileage: 6,686"Customer states when making right turns u hear clunkingNoise from left sidePerformed alignmentFound front right strut due to impactOrdered strut"Oil ChangePrice: $100.64
7/16/07Mileage: 6,912"Customer states noises from LF SOP herRight side strut 1722.0Replaced RF strut realigned and test droveNo noises"Price: $372.46
7/19/07Mileage: 6,957"Customer states knocking sound from front LF sideOrdered Lf strut"Price: $0.00
7/26/07Mileage: 7,013"Customer states noises coming from LF suspensionWhen going over speed bumps . SOPFound LF strut leakingReplaced LF strut"Price: $0.00
8/3/07Mileage: 7,160"Customer states car making noise when going over speedBumpsWhen going over speed bumps fast customer hears noiseFrom left front suspensionCould only duplicate noise when going over speed bumpsAt higher rate of speed. Advised customer that underNormal driving conditions noise not heard. We will tryTo identify noise at a later time. Customer to return"
"Customer states hub cap came looseWhile drivingReplaced hub cap"Price: $0.00
8/15/07Mileage: 7,446"Check noise from front left wheelNoise heard driving over speed bumps at about 15-20 MPHSwapped strut, spring, mound and bearing assy from know goodVehicle. Also removed aftermarket strut tower brace. NoiseNo longer present"Price: $0.00
While I never said anything about going over a speed bump "Fast" or "15-20 MPH" they put it on there. I will go over a speed bump a normal speeds and the noise is still there. Yes. The noise is still there.
Mileage as of now (rounded)Mileage: 7,700
Anyone else?
szh
Car: 2018 Tesla Model 3.
Yikes! That is a lot of stufff ... some minor, but ... more than I would tolerate on my car.
Z
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
I think it's only about half your car, and half the dealership.
WDRacing
From what you told me about the dealership Nazi's...I would never even let them fill up my gas tank.
WD
CodeRed
funny you say that. I picked my car up with the gas light on one time.
Ever Victorious
'73 AMC Hornet
matt_a
Ever Victorious wrote:I think it's only about half your car, and half the dealership.
When I read this post, I thought it was going to say, "I think it's only about half your car. The other half seems to be working"!
