zerepdivad wrote: Did you do the under dash wiring for the swap that includes the wiring for tach, rpm, and temp?
I hope you're meaning the plug on the pass side above the ECU. Other than that, there is no dash wiring for the swap.
zerepdivad wrote:If your car is an 89 i'm pretty sure you need a dohc ka cluster not 100% on that though.
Correct.
zerepdivad wrote:You likely blew your illumination fuse when "installing" your radio.
He said it all lights up, except for the taillights.... (If I separated the run-on sentences correctly.)
