r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Wed Apr 06, 2005 7:37 am
go to auto zone and buy some of those 18in 12 gauge battery cables (youll see the ones i mean). run one from the body to the block and one from the body to the head at least. ive got 4 total, one is attached to the intake manifold on the side where there is a convenient bolt located. another runs from a hole in the fender which i took down to the metal so the strap would make a good contact, to that stock hot pipe bracket at the front of the engine above the exhaust manifold. then ive got one going from the battery tray to the block and one from the battery tray to the same bolt on the intake manifold as the first strap.
sure you may think thats a little much but when i put them on it made the difference between my car not firing and my car starting instantly. for the 8 bucks itll cost you, i think its well worth a shot.
make sure the engine temp sensor isnt shot, and that the fuel injectors arent just staying open. sounds like an overfuelling problem. we had the same thing happen with my car and eventually it just sort of figured itself out. wish i could tell you we did something but in all honesty it just decided to work one day. oh and if you have a safc, make sure its set to 4 cylinders haha.
- tim
