Problems starting.
Jdmstyles
Car: My S13 took a crap on me.
So about a week ago my 240's positive battery terminal disconnected from the battery while on the freeway, and this has never happened before. The headlights and other lights started flickering and then I suddenly lost power. As a result, I popped the hood and reconnected the terminal. I attempted to start it again but it would only crank. Turns out I blew a fuel pump fuse. Fair enough, I replaced it on the spot and it started right away. A day afterwards I went to Autozone and got replacement terminals. After replacing them, the car starts fine, however, after a day or two, the car wouldn't start anymore during the first 15 tries or so. It wouldn't crank either, but rather it makes only one click. It would only start after many many tries. Once it starts it runs fine without a problem. However, after turning the car off and trying to turn it on again, the same problem occurs. I've tried hitting the alternator and it would start sometimes, bit I doubt that does any justice since the battery still has good voltage.
My question is what would the problem be then? I doubt it's the starter. I don't know how to troubleshoot this issue anymore, and attempting to start the car with sheer luck takes a while, and with that many many attempts as well.
Any input would be really appreciated.
r3v_v3ng3
Car: 91 fastback ka-t
take out your battery and get it charge at autozone/kragen or whatever and then have then check the battery (load test) to see if its the battery, while your at it if you have time remove your alternator and have it checked out. remove your plugs and replace them cause theyre probably fould out. also check all your fuses and wires to make sure no other blew out or melted
