burntricer wrote:
i really, really like that guide better. however, where did you guys wire in the ignitor?
I mounted it on the passenger side shock tower, where I removed the PS resivor (SOHC) 3 of the 4 holes lined up and i just drilled another one right quick. Looks factory too!
Anywho I printed out about 5 pages of info, thanks for the help guys!
Ill try first to:
-Remove and reinstall the ECM connector and make sure its tight to the ECM.
-Recheck all of my wiring with Frsport's guide and make sure each wire is connected and taped off correctly.
-Check all of the harness grounds according to the FSM.
If none of the problems are their I'll test the ECM/Ignitor chip.
I'll do so by using a multi meter to check for ignition pulses before the chip and after the chip.
And not to forget to check the ECM for codes itself.
Sound like a good battle plan?
