I want to buy the car, but could you all tell me what I would be getting into? I hear the problem could be related to a bad wiring job...if so, aren't there only a select few wires that would have anything to do with running like it is? (MAFS wires, ECU grounds etc.)
I guess the problem could also be an 02 sensor, is it the same o2 sensor as the 87 300zx turbo? Or do you have to special order it?
Another possibility is the MAFS itself, but that is supposed to be a NEW 300zx MAF, so I believe I can rule that out.
I think TOPS I am looking at a brand new wiring harness (LAST resort) and maybe a new o2 sensor, what do you think? I have heard there is a quick way to check for the o2 sensor by just unplugging it, is this true? Details?
The ECU is also a NEW #62 ECU, so I doubt it could be a problem with the ECU itself.
Would you buy this car knowing that it doesn't run well? The motor is perfect with perfect compression and a rebuilt transmission.
I appreciate the help and I'm looking forward to joining the SR20DET community.
