silentkrnsouljah wrote:ey peoplethis is my problem when i hit 3000 RPM it takes really slow and it just dont wanna take out then i can see the black smokes comming out from my exhaust it happens every gear and when i stop and put it in neutralRPM keep drops and up and downs its like about to stalled out or somethingi recently put the new timing belt and i check the all vacuum and boost leaki couldnt find none. maybe its time for the tune up? like new spark plugs and new fuel filter? or could it be MAF problem?i would appreciate for any help
Few questions for you:
Is your ecu stock or remapped/chipped?
Are you using the stock AFM or an uprated one (ie N60 or Z32)?
Did you check the codes on your ecu to see if it has trouble codes stored?
Are you sure you set your cam timing correctly when you installed your timing belt?
Did you make sure the ignition timing is set at 15* BTDC?
When your car got wired did you or whomever wire up the knock sensor?
Did you check your intercooler piping for leaks?
And lastly, are you sure your turbo is spinning freely?
For future reference, be very specific and descriptive about your dilemmas or your risk getting flamed and ignored.
Dee
