wajouba »
https://forums.nicoclub.com/wajouba-u67781.html
Tue Feb 26, 2008 3:44 pm
Ok, my problem is that I'm having strange rev limits... in my stock 200sx S13 as for example my car cuts off at 6900 or 7100 on 3rd gear, then goes on to cut on 4th gear at 6000 rpms, and it also cuts off at 5600 on 5th gear... but the funny part is when I let go of the throttle right after it cuts off and WOT again it passes the cut off by around 500 rpms then cuts off again...
Btw, this problem started happening after changing my engine and ECU, so I thought it could be the JDM ecu, so I went on and unplugged the Yellow Green wire on the 8th pin. Went for a try, it also did the cut offs, then came back and unplugged 2 sensors which I'm not really sure are the 4th and 5th gear sensors...
From the first time I got the car, the Speedo never worked, only RPMS, and while I'm under the car, I saw that theres a third sensor which was unplugged and put beside the transmission comming from above the transmission...
Any help, or pictures of the sensors, or even something similar to this would really benefit us!
thanks alot!!!
