problems from "shift lock"
itchy
Car: nissan 240sx
what are the main problems which can occure when using shift lock technique while drifting?because i am using this technique usually and now the wheels arent blocking as usuall.what could've happend?
s14_240sx
Car: 96 240sx Zenki
GTFO
itchy
Car: nissan 240sx
what
DRFT(kinda)
Car: 2005 Nissan Titan.
I wont be a d!ck. When I started using shift lock I had a $20 AutoZone clutch and a welded diff. After 1 drift meet and a few weeks on the street I replaced it with an aftermarket clutch and the AutoZone clutch was ate-the-****-up. As far as the transmisson, I can't imagine shift-locking wear the parts out. I would figure it would just break it althogether.
itchy
Car: nissan 240sx
thanks for sharing the info.so youre saying that the clutch could be the main problem?because for now i only have a stock clutch i am using shif lock for about 3 months so it couldve worn out?
DRFT(kinda)
If you have been doing if for 3 months on a stock clutch I would say it is definitly worn. Now, if you replace it with an after-market clutch, it is still going to wear out. I'm sure your a smart fellow and you know that clutch wear is going to happen, especially when drifting. But I hope this helps and have fun!
itchy
Car: nissan 240sx
thanks again.and maybe you or someone know if clutches from european s13 200sx fit on 240sx?
FUNGC
depends what engine you have man.
200sx has SR20's240sx has KA24's
soo answer is no.
itchy
Car: nissan 240sx
my engine is ka24de and would the clutch fit from ca18det?
and one more thing about my clutch: it works fine when accelerate but it doesnt work when i'm doing shift lock.so i'm interested why it works fine with acceleration?
itchy
Car: nissan 240sx
nightkid86
Car: 97 S14 SE
Shift lock is bad news for the transmission. If you want to use this technique either be ready to put in a new transmission or just do it in the rain sparingly.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
itchy wrote:what are the main problems which can occure when using shift lock technique while drifting?because i am using this technique usually and now the wheels arent blocking as usuall.what could've happend?
Here's an ingenious idea.... switch techniques, if you want to initate the drift try feint/liftoff or power over, and in the situations you would use shift lock just try clutch kicking.
itchy
Car: nissan 240sx
yee but shift lock makes fun so does anyone know if a clutch from ca18det or sr20det fits on ka24de?
ddgsxr504
itchy wrote:yee but shift lock makes fun so does anyone know if a clutch from ca18det or sr20det fits on ka24de?
Whatever... your transmission.
wankelTII
why not just buy a clutch made for the ka?
ddgsxr504
Yes and the answer is no and no and you fail... hopefully your transmission blows up so we can all be see how shift lock makes fun.
