redhorse64 »
https://forums.nicoclub.com/redhorse64-u27658.html
Sat Mar 31, 2007 2:34 am
Just to let ya know:When I installed my new OEM Thermostat I had the same problem as you & I eventually figured out the hard way, how to properly bleed my system. At the advice of a local Radiator Repair Shop guy, I filled the system with 50/50 coolant, from the top hose. Yes, by removing the TOP HOSE at the radiator end & filling the system that way. Then real quick put the end back on the radiator without spilling too much, and the using the little Air Purge Screw, I was able to get all of the air out of the system.So, all is fine now & running great.Take care,Red.
