catch221134 »
https://forums.nicoclub.com/catch221134-u48397.html
Mon Mar 31, 2008 2:24 pm
I have had the same problem, and it has stumped just about every one. I also posted up on nico several months back.
I have the usual mods': intake manifold, gt spec exhaust, aeromotive fpr, syoko outlet elbow, no cat, apexi neo and avc-r.
My car does the same thing, since i have switched to the intake. So I would advise all people to not go with one, unless you want to go all the rest of the way and upgrade turbo, waste gate, and so on.
The only other thing is that, my car has some weird boost creep problem. In first it will almost act like a boost spike, but in 2-5 it will hold at .55 bar and then creep to what every it wants to. Stock turbo, second one because of this issue. Any suggestions?
As for the others, I feel you pain, and it is quite embarrasing. You can't even drive the car, and if you are like me, have quite a bit sunk into something you cant even mob out in, or take to the track...a pity...
I think that tuning is the answer and the R&R is also the reason. So get it tuned. I was on the way to get mine tuned and this boost creep issue came up and the turbo blew up before I could get it tuned. But I did mess around and lean the fuel out in my neo at 5.5 to 6.5 (mine seemed to snap out of the R&R at 6.5 to redline) and it ran amazing...
If anyone has suggestions of the boost creep, please let me know. And I have switched everything on the engine, maf, plugs, all that stuff that fixes everyone elses. And have ran a boost leak on it, and it was fine.
