Problems after setting timing.........
siks13sr
Car: 91 hatch. RB in the works.
my car was running strong pulled good through all gears but timing wasnt dead on.... so i decided to set it today... i drove the car to my buddys house bc i dont have a timing light and it ran real good like its been... so i set it 15 btdc just the way it says on the forum here and i lost alot of power..... my car wont rev past 4 grand in first and 3 in all of the other gears... it hardly goes now... the only thing we messes with is timing, i dont understand what it could be!?
lrb_2000
Car: '91 Nissan KA-T hatch
mmm, this is sohc right? because dohc, is 20 degrees... make sure you disconnect the TPS sensor before you time it, and make sure it's idle is at 700 or it will be off.....
siks13sr
oh sorry i forgot to mention this is the sr20det...
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
How did you set your timing?
Florida240sx
timing light
siks13sr
i used a timing light as it says in the thread "checking your sr timing" posted by tenkaw akito...
InsanityInc
did you do whatever you have to do to tell the ECU that you're setting the timing? (probably disconnecting the TPS).
siks13sr
yeah i disconnected the tps also
InsanityInc
try resetting the ECU.
siks13sr
i was told by a friend to check the codes that the ecu might be throwing out... he told me a way to check them so im gona try that in the morning...
