IlyaKol wrote:Double E wrote:My Y34 did this after I dumped a bottle of seafoam into the brake booster line. Got the codes, bad idle, replaced the sensors, no joy. The cats had burned up from the seafoam dump. I added it too fast I guess. It got expensive after that.
I'm surprised. I've been using Seafoam for about 250kmi on 3 different cars. Haven't even had an O2 sensor go bad.
OP, was it just the sensor you replaced or did you run something like Seafoam before too? I'm curious.
I've used it on other cars successfully as well. In this case, the sequence was first adding it, then the sensor failed (threw a code), then the cats were found to be bad and I had a no-start situation. Replacing the sensors solved the no-start issue but there were some awfully bad knocking noises coming from the engine making me think the block was about to ventilate itself. It was just the remnants of the cat internals rolling around.
It is possible that the Seafoam addition was a coincidence ...and the failed sensor caused unburned fuel to dump into the cats but if that were the case...with as many of those sensors that go bad around here, I'd have seen the burned up cats issue happen more often.
