frigga »
https://forums.nicoclub.com/frigga-u4249.html
Wed Jun 09, 2004 7:17 am
A quick summary of what parts were installed:
- 30mm Z Calipers- 30mm X-drilled rotors- Front and rear SS lines to mate to the Z calipers
Alright, so it comes time for me to put everything on my s13, so I first take off the stock calipers and install the Z rotors and calipers. After that, I installed all the lines.
Then I bled the system quite thoroughly, in the order the FSM says. Double checked to see if all the lines were tightened, and began checking for leaks. There were none.
Bled the system again, knowing that because we've takin off all the lines, there must be a lot of air inside.
Here is the Problem:
Upon start up, when pushing the pedal down a few times, there was a very loud and noticable hissing sound coming from it.It felt nice at first, but as soon as I started to drive it out of my shop, and applied the brakes, the pedal went straight to the floor. It wasnt grabbing at all.
Checked for leaks again, and there were none.
I talked to a caliper rebuilder who personally has a 300zx and he said that it could be the seals between the two halfs of the caliper that were either broken or not torqued properly. I sent it out to him and had them rebuilt, and when we put everything back together again, same problem, only this time it made a little difference. Pedal was still going to the floor and not driveable.
If there is anything that I missed, or I should have done, can you let me know. If you can help me out as to what the problem is, it would be greatly appreciated.
