then its most likely battery connection problem or the alternator malfunctioning, when you have bad connection while driving, those lights intend to come on, check with dealer they might get you a new battery and ask you to drive for a while to see if the problem occurs again.morning_glory wrote:
By the way while driving later today I got 3 alarm lights:
- check engine;
- brake;
- battery;
So I really need to visit the dealer...
Thanks
wow, that was it, i didn't know if it had a sensor on the hood too.morning_glory wrote:Finally I got the diagnostic: The alarm was triggered by the hood switch. It had been damaged by water infiltration.
My dealer said that the problem with the abundant alarm lights was caused by the fact I removed the horn fuses. However I can't understand the relationship between the horn fuses and the alarm lights....
M.G.
