The car has plenty of power. It's not losing power at all. It's not lugging like a manual transmission car does when the RPM<'s are too low. It's not that. But thanks.Q45tech wrote:Important to make sure engine is able to produce sufficient power [torque] to avoid lugging [chug] at low rpm high load. Is problem worse with AC compressor on at 45-55?
Knock sensors and dirty injectors, induction \TB dirt?
Exactly...It is definitely the TCC lockup shudder. I did the flush, and added the lubeguard, but it still happens. Is there some sensor that will make this stop? Or can I use the Transmission Control Unit from a 94Q?elwesso wrote:I think its something like a TCC lockup shudder... Does it only happen when the torque converter is locked???
Disregard our email, i thought of something after i replied.
I think I understand your question. It only happens when I hold my foot steady on the gas pedal. If I let off or increase, evem slightly, the shudder goes away. I can even tap the gas pedal and it will stop. I think racers call it "feathering" the throttle. Again, it only happens on slight hills, not steep hills, and not on flat ground or downhill, only when I hold the gas pedal steady. By rapidly tapping the gas pedal, even very very slightly, the problem goes away.elwesso wrote:IN EITHER case (Lou or carlos), does the problem go away if you DO NOT DOWNSHIFT but you allow the torque converter to unlock?
Documented in Infiniti Online Mechanic Forum. Usually evident by leak along wires connecting sensor to trnamission along driver's side.carlosinseattle wrote:When you look on MSN Autos' reliability ratings it mentions something about a faulty "Torque Converter Turbine Sensor". It says there were frequent problems with failing torque converter turbine sensors on early Q's. Has anyone ever replaced one of those before??
Yea, if I don't downshift, it goes away. It just might be that the incline is over. It's not something that happens all the time on other places, but as I metioned, when I'm on Route 46 east heading to the George Washington Bridge, I'm sure James know where I'm talking about, it happens more than not. It's a minor problem since I don't take the highway too much. Hell, Wes, when I drove to Ohio and to Indiana 2 years ago to hook up with you, it didn't happen once in the whole trip. Also in the Winter, the Q is the car I take to the Poconos because it's the only car I put the snow tires on. Don't happen then either. This has benn going on for a couple of years and I've lived with it but it would be great if I could solve this.elwesso wrote:IN EITHER case (Lou or carlos), does the problem go away if you DO NOT DOWNSHIFT but you allow the torque converter to unlock?
Just to repeat for those who think it is a design problem. It is not. It is a mechanical condition problem.Q45tech wrote:This instability is a perfect test to warn of needed maintenance.
OK...WOW...OUCH!!!Q45tech wrote:You must keep the engine perfect [as in creating the as new torque ouput at low rpms] because the economy gear ratio [2.45 from 0.694 x 3.538] is just on the ragged edge of functionablity at low rpm in 4th gear.
Extra drag from misalignment or tires or weight in trunk or AC or just 10% down on torque at under 2000 rpm and it shows up.
US gasoline has declined in BTU since these cars were designed so the preprogrammed amount for 14.7 AF doesn't create the same torque as it did in 1990...............study BMEP.
Fresh spark plugs seem to make it better as does BG44k and a pristine clean intake/plenum system for a few months...............every single pound foot counts on some inclines.
The lighter Q41 used the same transmission gears and they had to go up to 3.694 vs 3.538.........4.4% increase because of the lower torque at 1500 rpm.
For the newer members, I will repeat that in town, below 60 mph, or up an incline, my cars stay in 3. Only downhill, dead level at maybe 55 mph, or more likely over 60 mph is car in drive.Q45tech wrote:We have an incline on I285 [ATL] where trucks slow down if it's very heavy traffic the average speed gets down to 45- 50 mph instead of 70-80 mph in Summer AC on even mine misbehaves sometimes...................I just drop down to 3rd and the problem goes away, when it opens up after the incline back to overdrive.
Well, I have been pursuing the stumble problem and replaced a coil pack so far.louiegz wrote:This is the only car that I've ever driven that this happens to. Does this happen to your Y33 Brian?
Well no, Dennis, it's not Nissan's fault on how people maintain their car or the BTU in current fuel, but I do blame Nissan for how hard it is to maintain some things on the Q. Things that should be simpler to promote people to maintain their car better. Of course, Nissan's objective is to sell new cars and not have us run our cars for 10-15 years. Anyway, you really shouldn't assume that everyone doesn't maintain their Q. Most don't as well as you do, but I've don't a better than average, at dealer prices keeping my Q tip top. I have about 90k on my 95 and the plugs were done for the 3rd time about 2 years ago and they even cleaned the intake and the injectors. I still run with the original injectors. The only thing I haven't done is the under plenum work, but I guess there isn't anything major going on there because I'm sure the dealer, as incompetent as they are, are always looking for something to repair. I'd like to have it done but I'm afraid to see how much they would charge me for that.Q45tech wrote:Is it Nissan fault that owners don't maintain to standard or that US refiners are allowed to produce gasoline that is so way below BTU standards to compensate for rising fuel prices.
