Problem with TPMS
dkrep
Car: 2004 G35c
Ok so heres my problem my low tire pressure light is coming on but when i check my tire pressure there all at 32-35psi i turn the car off and it resets it self. but now its coming on and staying on but all the tires are at the correct psi. Anyone had this problem before or anyone know what it could be. My car is an 04 G35c 6spd
telcoman
dkrep wrote:Ok so heres my problem my low tire pressure light is coming on but when i check my tire pressure there all at 32-35psi i turn the car off and it resets it self. but now its coming on and staying on but all the tires are at the correct psi. Anyone had this problem before or anyone know what it could be. My car is an 04 G35c 6spd
Welcome to NICO
You could have a defective sensor. Your gauge could be off also so try adding a couple of lbs of air to each tire.
Use a good quality air gauge
I've had two defective sensors that were replaced under warranty at the dealer.
http://www.amazon.com/Moroso-89560-Tire ... B000COS8FI
Telcoman
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
yes, my 04G35 coupe currently blinks after hitting bumps in the road.
Also, the 08G35 Sedan's light blinks and then stays on.
Tire pressure is fine in both.
WAldenIV
Car: 2007 Infiniti G35x
2008 Infiniti G35x
The TPMS sensors break periodically. I've had a couple replaced already.
