problem with the power steering on my 96's i30
xddy
the steering of my car is very loose, I can make turn pretty easy without too much resistance, and after I made a turn, the steering wheel can hardly return to the neutral position automatically, especially when the car runs at a low speed. I have to turn it back by hand although it is as easy as I made the turn. At first I though that might be the problem with the tie rod end. But after I replaced both inner and outter tie rod end, the problem is still there.The PS fluid is in the normal level, and no leaking found. Anyone can help find the reason of this problem? or put this topic in a proper forum because it might be a general problem. Thanks.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Welcome!
You may have a bad pump or rack.It's also possible that there's something blocking or restricting fluid flow
xddy
Thanks for your post, so how to figure out where the problem is?I can not hear any abnormal noise from the pump, but I dont know how to check the rack and the pipe. can anyone tell me?thanks a lot.
MinisterofDOOM wrote:Welcome!
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
When you drive down the road at high speed are you getting a lot ofvibration, wheel shimming, noise etc?
xddy
NutriaforBreakfast wrote:When you drive down the road at high speed are you getting a lot ofvibration, wheel shimming, noise etc?
Actually, there is no noise but some vibration around 70mph, also, sometimes it sways a little bit even at low speed, is it a balance or alignment problem?
