problem with the front plate to get to timing
caleb travelstead
Car: 1990 nissan 240sx coupe
im having a problem taking off the front plate to get to the timing chain guides.i have all the bolts removed with the pulley's and everything like that. i have a KA24E motor. if anyone can help i would appreciate it greatly
caleb
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
pics?
Wretched
Car: 93' Hatch
Not sure on the ka-e...but there might be two under the valve cover. Also, might be two on the bottom that you have to remove the oil pan to get to. Can anyone verify this?
caleb travelstead
i have the a/c off and the thermostat off also, as well as the o/p
Wretched
Car: 93' Hatch
K, nm...did you take those two 10mm bolts off the top?
caleb travelstead
yes sir
Wretched
Car: 93' Hatch
Nissan is known for hiding bolts...but they also get stuck on the dowl pins too so it may just need a little pry bar action to get it off. But I'd wait until one of the real ka-e guys can chime in for any hidden bolts.
caleb travelstead
ok
thank you for your help
baron_harkkonen
Car: 1993 Nissan 240SX, 2005 Honda Civic
did you take the water pump off or check behind it? their maybe one or two behind it. and w/e you do DO NOT pry on it, its made of aluminum, it will break. I SEE THE PROBLEM!!!! You have a bolt that connects the top part of the cover to the bottom part, right above the water pump housing. also one down and slightly to the right. get them off and see what happens. get a flathead and ever so slightly push between housing and head see if you have some clearance.
Modified by baron_harkkonen at 4:32 PM 10/4/2009
caleb travelstead
yess i did. there weren't anythere.
nos487
Car: 86.5 nissan V6 5speed truck
There are 4 10mm headed bolts on top. check this out might help http://www.nicoclub.com/articles.php?id=220814
baron_harkkonen
hey dude, these pictures current?
caleb travelstead
last nighti took a few things off today
baron_harkkonen
Quote »[/quote]on this pic, right above the water pump housing, there is a bolt facing down connecting the top and bottom covers, and diagnolly to the bottom right, there is a bolt holding the cover on still.
caleb travelstead
i have those off also. i dont know what could possibly be holding it on.
VRoy
Car: 93 S13 Hatch
Read the Tech. Article again. Did you remove the oil pump? cover wont come off until you do.
caleb travelstead
yes i did. i did that today
jeff420
Car: too many to fathom
i see a few bolts that should be removed. i know on the dual cam motor the oil pickup is bolted to the block and you need to remove the oil pan. i see at least 7 bolts that you need to remove. and for the love of god please clean that cover!!!you may find some more bolts under all that mess lol. plus it will make working on your car so much nicer becasue you wont get so dirty.
also have you removed the bolts that go from the oil pan to the front cover?
caleb travelstead
haha.i have those off already also. i wish i had a more recent pic. i work on it today and took off a lot of other stuff. i don't know it its just stuck on there or what. is there a certain way to break it free or somethingand i plan on cleaning itit really needs it bad
jeff420
go grab some engine degreaser and clean it right now lol. they do tend to get stuck on there but i dont recomend trying to pry it off until you are damn sure every bolt is off. i knew one guy (total moron) who tried prying his off in the wrong spot and busted his new timing cover. the reason he was replacing his old one was because he busted it too that way lol.
and when you do try to pry it off dont pry just kinda "jimmy" it around dont use force. there are spots on the dual cam motor where you do that i dunno anything about single slammers but ive completely dismantled a few dual cam ka's by just looking at them and just goin for it. my first step was to clean everything
Modified by jeff420 at 6:07 PM 10/4/2009
caleb travelstead
hahaha..wow. will break cleaner work
everywhere where i live is closed
jeff420
it should. its flamable right? lol. do they not have a walmart where you live? open 24/7 i used simple green and engine degreaser. its tedious but its so much nicer to work on a clean engine. you'll need plenty of rags and show towels maybe even a tooth brush and puddy knife to kinda slough off all that gunk.
caleb travelstead
haha..yea they do. but i dont have a ride there.
jeff420
damn that sucks.......invest in a dirtbike lmao. thats what i did.
caleb travelstead
i wish i had that kind of money, i would.
jeff420
i traded for my 09 crf150. my atv payment is only like 130 per month. and it cost twice as much as my dirtbike would have. friggen payin on the 08 but my 09 is paid for, rediculous lol.
well id try with the brake cleaner its better than nothing. just be conservative if thats all ya got. your gonna have to wipe most of that gunk off. just be careful since you already have the pulley off.
caleb travelstead
ok i will. thanks a lot guys for your help
Drift-Master
Car: Nissan RPS13
Remove the Oil Pan then you will see the oil pump- remove the two bolts from the oil pump and the front cover will come off.
baron_harkkonen
I've got an idea! Go to your nearest fireworks distributor and get "little dynamites." Insert them behind the cover and ignite. Stand back and get the somone that you dislike and tell them to stand infront and it will be ok aslong as they cover their ears.
Nissan409
Car: 1993 Nissan 240sx
Ive taken those off before and i never had to take the oil pan off, throughly check all the bolts to the plate you want to take off. I know when i helped my buddy with this, we had to take a hammer to get it off. I dont encourage using brute force though, incase it breaks. We didnt break it thankfully, the exhaust cam snapping off did though!
