zengshengliu »
https://forums.nicoclub.com/zengshengliu-u122532.html
Sat Mar 30, 2013 6:54 pm
I have a 08 Rogue with HID light. The light housing has a adjustable height. Recently when I apply the turn left turn signal without any other lights on, both headlight will keep on adjusting up, and since it reach the max height, it makes a popping sounds (where the housing bounce back and adjust up again and bounce back again and repeat)
It doesn't happen on right turn signal, or when the side marker/headlight is on. It only happen when the left turn signal is use and no other light is on.
Anyone has any idea what might be the problem?
