Im not sure by what you mean when the bulbs are ok when you hazard since the turn signal bulbs have nothing to do with your brake lights. I also dont think its your fuse since your brake lights are partially working. Soo my guess is that your left side brake bulbs are faulty. I would pull them out and inspect that the bulbs have both filaments intact. Another simple way to see if its the bulbs is to take the ones from the right that do work when you engage the brakes and place them on the left side. If they work then it looks like the secondary filament on the original bulbs on the left side are gone. Give this a try and let us know how it works out.fresno240sx wrote:my tail lights have been working but than its weird....when i brake it comes on like this:
its weird because only the two right light works and the rest dead...the light bulbs are ok cause when i hazard..everything comes on...someone please help????
Modified by fresno240sx at 3:27 PM 8/6/2007
^^ Good point.If you still doesn't work, you might want to remove trunk interior trims and see if any wires are damaged from rubbing. cmkelly had a prblem with his antenna before that way.ishkabibble wrote:-first replace the bulbs. might as well do all of the brake bulbs at once - 1157 bulbs for the main brake lights, 921 bulb for the 3rd brake light-if they still don't work, check the wiring for bad connections and the bulb terminals for dirt or corrosion-last resort is replacing the bulb holders (I had to do this on one of my taillights)
