slakker »
https://forums.nicoclub.com/slakker-u10544.html
Sat Oct 23, 2004 10:54 pm
I absolutely believe it is nothing more than that your gauge cluster isnt getting power. The ecu is fed from wiring which comes from the cluster. I have had the same problem except my guages flashed on and off. When it went off the governer kicked in at 5k. I know that you have the HUD. Very common problem. Switch to analog guages, or search on here for HUD. This will give you everything we have ever talked about on this retarded topic. Been there. My particular problem was that the plug closest to the digital speed lcd had a loose connection. I had to ziptie the wires to put pressure on them for it to make continious contact. There are many reasons this happens and many fixes. You'll have to search. Good luck. I am currently going to analog, because the [problem will not quit driving mr nuts
