spotteddawg »
https://forums.nicoclub.com/spotteddawg-u36004.html
Fri Sep 01, 2006 3:00 pm
hooked up the safc2 a bit ago and setting it up.There is no RPM signal or Knock singal.Everything hooked up right its like my 10th safc2 hook up,but my first on a 240sx w/sr20det motor and the ECU62 is the one that came with the sr20.Jay over at Augusta Customs did the swap.Sooo I have a few questions.1.Can the car run with out a RPM and Knock signal going to the ECU?2.Where does the RPM signal come from on the engine and if possible the wire color?
The car runs great and strong pullin bish!So if the ECU doesnt need them two signals,seems as though it dont, I will run those to signals directly to the SAFC2 so I can start using it until I get it to Dyno.Thanks Spotteddawg
