DALAZ_68 »
https://forums.nicoclub.com/dalaz-68-u62157.html
Thu Sep 13, 2007 7:31 am
ok so ill try no to longate this
simply put my SOHC blew...friend had an S14 KA not in use
engine was converted with s13 DOHC parts for swap...DizzyIgn Coil (new)alternatorengine harness (MT)ECUMAFheaderstemp sensorTB w/ MT TPS
mated the S14 KA with my SOHC Mt transmission
first problem was no sparkwhich has been resolved
new problem...fuel pressure
simply put the pump prims as it should...pressure is built...turn the key, it starts up...but then boggles and ies due to fuel pressur not being constant...
im stumped...mechanic is stumped
weve even switched out all the converted parts with others...even the engine harness and ecu
if we feed it quick start and or carb cleaner and or brake cleaner constantly, it stays alive, and but idle isnt steady
things been set for TDC several times from pulley and dizzy, both doen together
im lost guys i need help...my car has been down for to damn long now...and im loosing hope.....does anyone know or have any idea wuts going on?
