Jagstang »
https://forums.nicoclub.com/jagstang-u119184.html
Tue Nov 08, 2011 3:31 pm
Sorry for bumping this from the dead, but these control units seem to fail quite frequently, so I wouldn't buy it used. I called the dealer to see how much it costs, and wanted to give the part number (located on the control unit casing) to the lady on the phone, and she said "let me guess" and she literally repeated the part number over the phone... She actually had it memorized. I told her it must be a pretty common problem, and she said yes.
So the pricing for it is $238 CAD new (f*** insane), and with my Nissan discount, dropped to $197 (which is still a BS price). So to fix this issue, I just took the casing off, and soldered some metal on the cracked solder points, and now it works perfectly.
So if you guys ever have any issues, take the case off (no BS clips or whatever, it just slides off)and solder all the weak looking solder joints and you'll be good to go!
Oh also, do the same thing with the S14 drivers side window amp. Those solder points start to crack, and in hot summer days, you can't bring the window down.
Jagstang... OUT.
