Densetsu »
https://forums.nicoclub.com/densetsu-u91979.html
Tue Oct 20, 2009 7:37 am
Whenever the tail lights don't work, I'd suspect, in order: fuse, relay, switch. Since in your case the tail lights work in the ON position, I'd only suspect the switch.
However, the FSM troubleshooting guide says this symptom (headlights work in ON and AUTO; taillights only work in ON, not AUTO) can ONLY be caused by a faulty auto light sensor. Which really makes no sense to me, because the headlights work in AUTO and there's only one circuit for the light sensor signal. But that's what the service manual says, and I suspect the Nissan engineers know more about it than I do.
There is a series of tests you can do to see if the light sensor is working properly, if you can get your hands on the FSM. I believe there's a link floating around this forum somewhere.
