Problem with rocker arms on 1990 KA24E, PLEASE HELP!
David s12
Car: 84 datsun s12 ka24 swap
well damn, i picked up a KA24e that runs, but the rocker arm studs have been loosened
well i went to tighten them, and i noticed one of those clips starting to bend upward as i tightened it
so i was like wtf, and i tried the same bracket from my parts kano luck
10 pounds of pressure i usedwhy did it do that!
please help
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
What does the FSM say the torque spec is?
It's off center and the edge of the keeper is bending up on the edge of the rocker shaft... I don't know if that's how it's supposed to be or not.
If it keeps doing that, just torque the bolt to spec, then bend the keeper back so it keeps the rocker arm centered over the lobe and valve.
David s12
i tried bending it but it doesnt work,
the torque spec is 30, and thats only 10, i did them in order to 30
i dont have the manual but my friend sent me the torque specs
David s12
guh. seriously no one can help me
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
dont trust your buddys specs man..most mistake (inch pounds) and (foot pounds)..there is a huge difference..i know for fact the ka24de head is inch pounds not foot pounds..so to give ya an idea..30 inch pounds is like 4-1/2 foot pounds..sumpin like that..its a huge difference..so to save your self some trouble..but the repair manual and read a bit..good luck.
David s12
inch pounds.
hmm
180weaver
Car: 90 240sx
I haven't had any problems like that on my e but it is inch pounds, and without looking at the manual i think it is somewhere between 17-30 and you need to sequence it. I reccomend spending the 20 and getting the chiltons, but if I get around to getting into my car I will post it for you
spank044
Car: 1992 240sx with a Supercharged 350Z VQ for a HEART!
liquid_cool wrote:dont trust your buddys specs man..most mistake (inch pounds) and (foot pounds)..there is a huge difference..i know for fact the ka24de head is inch pounds not foot pounds..so to give ya an idea..30 inch pounds is like 4-1/2 foot pounds..sumpin like that..its a huge difference..so to save your self some trouble..but the repair manual and read a bit..good luck.
I really hope you are talking about the cam retainers in inch pounds. Also 30 inch pounds is 2 1/1 ft. lbs. OP- Those torque down to 30 inch pounds. The reason it bent up is because it caught on the edge of the rocker. Just bend it down with a pair of pliers so it barely touches the rocker shaft and doesn't come in contact with the rocker. If you have feeler gauges stick the .010 in and bend away.
