z-monster »
https://forums.nicoclub.com/z-monster-u34871.html
Mon Aug 14, 2006 1:03 am
hi guys.... as most of you all know the rb25det is the only rb series engine plagued with this ncvt problem... the problem i'm facing is that after 4000rpm the second cam setting is suppose to kick in and the cam pulley is suppose to retard or advance to continue the climb in TQ and HP... i dont have my dyno chart but my car has a max hp rating on the wheel of 190hp@4125rpm from that rpm the hp and tq drops at a rapid up down rough chart movement. i was told that the problem is due to a bad cam pulley thats not retarding or advancing when its suppose to. if anyone of you guys here can give me a solution to this problem i would appreciate it. i expected to see something like 230Whp on my car that has an intercooler upgrade, HKS high flow pod filter, 0.8bar boost, and regaped iredium plugs.... 0.6mm
thank youkevin
