Problem with PSI indicator and how do I reset the tire rotation indicator.
All things Altima Coupe.
ZQ8 Blazer
My wifes PSI indicator will come on sometimes so I'll check the PSI and it may be 1-2 psi under or over the recommended level. Is there anyway to disable this function?
Also a light came on yesterday that said tire service or something like that. She's got 6k on it now so that just means the tires need to be rotated and nothing is wrong with them correct? How do I reset this?
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
That sis correct about the tire maintenance light. Not sure what factory default is but I have mine set at every 4.5K to rotate.
As for the PSI, make sure you check it cold but for someone who has a lift in their garage, I'm sure you knew that. If that doesn't help, have your dealership look at it since they are the only ones that have the right tool ( some box and a wand) to reset the TMPS sensors. Hope that helps and OH..Welcome to the forums man
ZQ8 Blazer
Yeah ha ha, I knew that.
Ok thanks I'll take it up there. I know on my 99 GMC show truck I had the dealership remove the autolock function(where it automatically locks the doors when you reach 15mph) I'm hoping they will do it at the Nissan dealership too.
ZQ8 Blazer
BTW I meant to tell you that if you're checking the tires hot you add 3psi to what the gauge says. You have to think that most gauges aren't going to be 100% accurate, just like the gauges in our vehicles aren't.
