fatire_mtb »
https://forums.nicoclub.com/fatire-mtb-u60934.html
Wed Sep 17, 2008 5:15 am
2004 G35 Coupe. 5AT.
A gremlin has somehow made it's way in to my power moonroof. From the closed position - Normal operation was one forward touch to the button to have the roof crack open in the back. Then one touch in the rear direction to the button and it would close. Then one more touch in the rear direction and it would open all the way.
Along came a gremlin.
From the closed position - Now when I make one forward touch to the button it cracks open in the back, but when I follow it up with a hit to the button in the rear direction it does not close. The roof then cycles past the closed position and continues to open, but only opens about halfway. Then from that position if I hit the button in the forward position to close the window it cycles past the closed position and goes back to the down in front open in back cracked open position. To make it even stranger if I hit the button either forward or backward and catch the window in just the right (closed) position and hit the button again the window stops in the position of the second button hit.
Any ideas? I'm at a loss on where to start.
