Problem with power in storage box
All things Altima Coupe.
kruuth
Hi all. I was trying to use a tap connector to add power from the outlet in the storage box now I have no power down there. Did I blow a fuse or something? I had unplugged the wire to the outlet and had tapped successfully off there before for my radar detector, now there's nothing down there.
This is off an 09.
DAAN.
Change fuse
Ranga14
Car: Boosted 08 Altima Coupe 3.5
lol, I have the same issue. But I never use it so I haven't really messed with it any further.
kruuth
Yep, that fixed it. The Radar detector fired up for about 1 second and then I blew the fuse again...What I've got down there is a pair of wires attached to the outlet via tap clips, and off those wires I have 2 cig. lighter adapters, and now a 12v line running into my trunk. Do I need a stronger fuse or something?
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
kruuth wrote:Yep, that fixed it. The Radar detector fired up for about 1 second and then I blew the fuse again...What I've got down there is a pair of wires attached to the outlet via tap clips, and off those wires I have 2 cig. lighter adapters, and now a 12v line running into my trunk. Do I need a stronger fuse or something?
Whats in the trunk? Id say you def need a bigger fuse but not sure if that will cause other issues. The fuse is a certain size for a reason, if you are drawing more current then you are supposed to could cause issues elsewhere?
kruuth
I'm trying to run 12v to my trunk. I figured I'd use a length of thin lamp cord. It's just insulated stranded wire. This happened when I attached that. It's not running to anything in the trunk yet.
DJ_B_Easy
kruuth wrote:I'm trying to run 12v to my trunk. I figured I'd use a length of thin lamp cord. It's just insulated stranded wire. This happened when I attached that. It's not running to anything in the trunk yet.
Im no pro, but I dont think this is a good idea. If you need wire that heavy duty I would run it straight off the battery. Not sure what else is on the circuit to the power in the storage box from stock, but I highly doubt that circuit was designed to pull that much current.
What are you planning to run off the 12V in the trunk?
kruuth
I'm actually adding a backup cam, and there's not really a good key-active 12v back there. Turned out the short was because the end of the wire was frayed and contacting the positive to negative. When I cleaned it up the problem went away.
DJ_B_Easy
Cam should be fine, it sounded like you wanted run something bigger than that, I misread.
