Problem with power after 5500rpm
canary-s14a
Car: silvia s14 kouki
Hi, i dyno test my s14 last week and have a problem, the power comes down after 5500 rpm
What can be the problem or what should i test?
the compression is 135 psi (little low so maybe this is the problem), the a/f with stock fuel pressure (43 psi) is 11:1, and in that dyno test i low to 40 psi to reach 11,8:1, it doesnt seem to be any boost leak, the engine have a rattle sound, maybe the vvt or maybe lifters, not sure...
And this one is how it should look like one with same mods and same ecu chip upgrade
Im running, gt2871r boosting 1,4, full exhaust with manifold, intake, fmic, walbro, z32 afm, ngk 8 plugs, blitz sbc controller
Can read more about my problem here:
http://www.sxoc.com/vbb/showthread.php?t=434511
